Originally posted by Junah
When I switched it on to test it, it hums but test light never comes on, is it faulty?
By "the test light," do you mean the "power indicator" on the TR-3? If yes, it should come on.
If you mean the "ready pilot lamp" on the AF400T, If it hums but the pilot does not come on, the capacitor is probably toasted. I don't think it's worth repairing.
I also have a TR3 battery pack to connect to my AF540 but the cord does not fit the AF400.
Would it be worth trying to find the correct cable, or is there a fault on the AF400?
I don't think Pentax made a generic cable to use with the TR-3. From what I know, the cable for the TR-3 works only with AF540FGZ and AF500FTZ. You may be able to make a cable for the AF400T, however.
This post may help:
link.
I have put new ever ready batteries in, should I try Duracell?
You don't have to use any particular battery brand.
What are the best settings to test it on? (off the camera).
Let's try to make the flash to fire first.
