Originally posted by maxfield_photo I suspect you've had a run in with our old friend (or foe, depending on how you see it) the inverse square law.
I do think your point makes sense and even though I "understand" the inverse-square law, I didn't expect it to have such an impact. This could be because I have limited experience with flashes and also because it didn't feel like I moved that much between shots.
I haven't done too many tests since I started this thread but I do not think the light is being spread in an odd pattern. The light fall thing must be what has been going on - I need to experience it again, and then try to work with it to better understand it.
Originally posted by amoringello Another question, is the YN-560 output stable/consistent?
It sounds like a decent flash for the money, but it may be worth doing some controlled test shots (stable environment, on a tripod, etc...) to make sure it isn't actually causing the problem.
the amount of shits with flash, and the YN-560 on top of that, is relatively ery low compared to none flash exposures. But it¨'s still a great enough number, and diverse enough usage that I do not think that is the problem. I've plenty of times had the camera of a tripod while also using a single or more flashes and never experienced output consistency issues - even when I later look though the photos, I might have trouble telling the YN apart from the Metz as they are very close in output capabilities.
