I'm considering purchasing a softbox and a bracket to mount a flash behind it (not a fan of lamps). There seems to be two types of brackets that attach to the softbox. One has the flash in a "regular" position (as it would be behind an umbrella) and the other has the flash mounted on a vertical axis, so the flash body is actually horizontal (with the head placed as it would be for bounce, if mounted on the camera).
Am I at all clear?
So, the question is : which orientation is best? What are the pros and cons of each?
Thanks, folks
