02-20-2013, 01:19 PM   #1
cardinal43's Avatar
Which Ring Flash?
Hope this is in the right section. I'm looking for advice regarding a ring flash. I have recently picked up the Tamron 90mm Macro from a fellow forum member, and I "think" I want a ring flash. I've never owned one, and have only used a flash ring 1 time. I have no clue which one I should get, so I'm looking for advice/info as to what I should be looking for. I received a $50 Amazon gift code, and thought I might use it on the ring flash. I looked at the ones on Amazon and they generally run in the $50 range, but I have no idea which one is good and which one is junk. Any information would be appreciated.
02-20-2013, 01:53 PM   #2
The best ring flash is one with p-TTL, then you don't have to worry much about exposure. But p-TTL ring flashes are not inexpensive.
The next best thing is a flash with manual power ratio settings.
Auto mode is helpful but not so much so in macro. The thyristor sensor can easily be fooled. Also, the effective aperture can be 1 or 2 stops slower than the aperture setting on the lens.
Buy this. It has auto mode, and 5 manual power settings (1, 1/2, 1/4, 1/8, and 1/16).
And this (Don't worry about the fact that the module is not for Pentax. It doesn't matter).
There, not from Amazon but a great ring flash for about $50.
This thread may help.
02-20-2013, 02:15 PM   #3
bluestringer's Avatar
I second SOldBear's advice. I have this ringflash and it works great.
02-20-2013, 02:54 PM   #4
cardinal43's Avatar
Thank you gentlemen for your quick reply and excellent info.
02-20-2013, 03:21 PM   #5
Bob from Aus's Avatar
Sigma ring flash is not a ring, but 2 small flashes mounted in a ring - this is a bulky piece of gear and takes up a lot space.
Pentax is a true ring flash - it is much smaller, but may not fit on some sigma macros - I have never used it
I prefer to use manual settings both on the camera and flash as well as manual focus.
There are LED alternatives, these would be great for fill light, but I am not sure if much else. I have LED lights that can be mounted on a tripod or camera bracket and they do a nice fill in light but it doesn't change the aperture in reasonable light and does nothing in bright light.
02-20-2013, 04:52 PM   #6
How about something like this:
https://www.pentaxforums.com/forums/pentax-flashes-lighting-technique/74768-o...one-tried.html
02-21-2013, 09:36 AM   #7
I use a Vivitar DR-5000 ring flash. It's a true ring flash & works great. It's $52.99 at Amazon. No p-TTL, but it does have an auto setting that works well.
amazon, flash, lighting, photo studio, strobist
Which reverse ring? geekette Pentax SLR Lens Discussion 11 06-02-2011 10:34 PM
Which flash- Metz 50 AF-1 or Sigma Flash EF-610 DG Super TOUGEFC Flashes, Lighting, and Studio 25 04-25-2011 06:27 AM
Ring flash / ring light for macro tcom Flashes, Lighting, and Studio 5 07-28-2007 10:26 AM
Opinions: Ring light or Ring Flash Peter Zack Flashes, Lighting, and Studio 8 07-14-2007 07:44 PM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
