My experience has all been with variants of the Cactus triggers, but maybe some of this relates.
a. One time I thought the flash was not working and replaced the batteries on the spot - still no luck. Problem: turned out that i had the flash power down so low, like 1/128, that it didn't show up in the picture and i couldn't see it. Solution - increase power
b. The cactus always used triple A batteries. They seemed to not keep their charge very long. I always had better luck recharging them right before the usage to some degree. I was also easy to leave them on without being conscientious about turning them off between uses. At least the transmitter mode was rated for a football field length, and that seemed to drain it faster as well - at least thats what i imagined.
c. There's chargers and then there are better chargers if using rechargeables. To make sure you charger is not the problem, try fresh akalines and see if that makes a difference.
best of luck, radio triggers are great when they work :-)
