04-20-2013, 09:13 AM   #1
GeneV's Avatar
Whatever happened to the potato masher?
I still use my AF 400T, especially with film bodies. It is built like a tank, has lots of power options, runs off 6, rather than 4 batteries which last longer, and on and on. I would use it more if my Pentax digital bodies would work with TTL. Big diffusers can cover up the sensor, but the sturdy construction of this baby will hold a softbox with ease.
If you shoot weddings or similar events, you end up putting together a bracket, cords, ball joints etc. to turn an AF540 or clone into a potato masher. However, Pentax does not make these workhorses with all the features of a modern dedicated flash.
I suppose one could order one of the expensive Metz units which seem to get mixed reactions, but I'm not sure the SCA adapters give full functionality.
04-20-2013, 09:45 AM   #2
I thought we were going to discuss these:
04-20-2013, 10:38 AM   #3
GeneV's Avatar
QuoteOriginally posted by calculator01 Quote
Those work pretty well, but the light output leaves something to be desired.
04-20-2013, 11:38 AM   #4
Still using them. I currently have: Metz 60CT-4, 60CT-1, 45CT-4 (X2), 45CT-1, 45CL-4(X2), .Sunpak 555, 522, Quantum QFlash T2 (big and heavier than most potato masher).
But I currently use Sunpak 120J (I have 2 copies) with a Lumedyne MicroCycler or a Quantum Turbo Compact.
See my signature.
04-20-2013, 01:35 PM   #5
GeneV's Avatar
QuoteOriginally posted by SOldBear Quote
See my signature.
The QFlash looks like a great option for Canon or Nikon. How is it used with Pentax?
04-20-2013, 03:57 PM   #6
Arjay Bee's Avatar
Still using a Nissin Auto 5200G - tested the voltage first and it is well within tolerance - great for illuminating large spaces..
04-20-2013, 04:41 PM   #7
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by GeneV Quote
Yep, me too I've still got a couple and you pick them up fairly inexpensively these days too.
04-20-2013, 05:17 PM   #8
45CT-1
Me too. Original owner as well - over 20 years old and it still works a treat.
04-20-2013, 06:54 PM   #9
Steinback's Avatar
I have two Metz 60 CT-4 systems for times when I need serious flash power. They work better than I would have expected with the K-01, with the only serious downside being the relatively heavy battery packs.
04-20-2013, 07:14 PM   #10
GeneV's Avatar
QuoteOriginally posted by kerrowdown Quote
These things are really built, too. I had one on a light stand fall down a set of bleacher stairs. It shrugged it off.
04-21-2013, 07:26 PM   #11
What happened is higher iso in cameras...they just aren't needed as much...and the fresnels make the new flashes almost as bright as the old mashers (measured w/ a light meter)...
04-23-2013, 04:35 PM   #12
GeneV's Avatar
Certainly, a modern DSLR at ISO 200 or even 400 is better than some films of 30 years ago at that ISO, but a well lit scene with indirect light still takes power, especially in a large hall.
The other point to me is that we keep paying three figure amounts for a bracket on which we place a shoe-mounted flash. The need for this configuration is there, so why not make the resulting contraption stronger and increase the battery capacity?
05-04-2013, 07:07 AM   #13
Man With A Camera
Racer X 69's Avatar
This is what came to mind for me:
And the light output is higher than the kitchen model!
05-08-2013, 06:43 AM   #14
GeneV's Avatar
Is it filled with flash powder?
05-08-2013, 08:11 AM   #15
Man With A Camera
Racer X 69's Avatar
Um, I think more like "flash~bang" powder!
bodies, flash, lighting, pentax, photo studio, potato, strobist
So what happened to the K-3 ? jogiba Pentax News and Rumors 372 09-30-2012 03:30 PM
Error What happened to the print size slowpez Site Suggestions and Help 2 02-02-2012 12:11 PM
Whatever Happened to Kodak High Definition? mblanc Pentax Film SLR Discussion 11 09-05-2010 07:36 AM
All times are GMT -7. The time now is 03:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
