Eric: those are both good resources for techniques and home-made gear. Specifically the following link will take people to the Strobist
discussions tagged with Pentax. There lies juicy info! To summarise some of this for people needing to work on the cheap...
A wireless system can be set up with the Cactus Wireless V2s, which is works fine over a limited range. There are certain restrictions, mainly that the flash can't have a trigger voltage over 12V. Sourced from
Hong Kong the transmitters are €22 and the receivers €14, which certainly makes it inexpensive enough to experiment with. And a lot less dear than the Pentax brand gear that is corded. Another wireless alternative is to buy off eBay, but people have had varying results depending on the gear combinations.
Recommended inexpensive flashes include the Vivitar 285HV and Sunpak 383. Both are robust enough with plenty of power and safe sync voltages. The Vivi tilts and zooms. The Sunpak tilts and swivels. So it comes down to whether swivel or zoom is more important to the application. These are manual flashes intended for users dedicated enough to learn how to be st use them. They are not P-TTL and not optimal for quick changeable use sitting on the camera.
The Pentax K100D is specified to work with up to 25-30V trigger, a lot more than other digital brands, so it is quite safe to use most recent flashes, though not specialised strobes.
Again, just a short summary of the wealth of info (some conflicting) that is available. Is there a FAQ for this?
