Originally posted by Nass hm, how do you do that? I have the 58-2, how would I set this up?
Thanks
It appears to only work in one of the automatic modes, either TTL, pTTL, or A mode. I've had the most success with A mode and with the camera set to manual due to the unpredictable nature of pTTL.
When you're in one of those automatic modes at the "main menu" on the flash unit, hit "sel" and arrow down until you see FB. Hit enter and it will display FB 0. Arrow up and down to set the 'width' of the bracket in stops, then hit enter. So for instance if you set it to FB 1, the flash will fire at three different levels on the next three shots. The first shot will be the "correct" exposure, the next will be one stop under, and the last will be one stop over.
It doesn't seem like the user has any say-so in the order of bursts, they always go 0, -1, +1, and there are only three shots in the sequence. Also, after the three shots, the flash will exit bracket mode, and if you want to do another bracket, you have to re-enable it. Some users will find this behavior annoying, others will think it a Godsend.
