Originally posted by hangman43 Not really sharpness more of detail being able to see all the facets in a multi-faceted eye when you fill in all of the crevices in a subject with light you lose texture because without shadows the low and high spots look the same.
You are trying to describe Specularity - in which case a larger light source like a softbox is beneficial, But a ringflash can be just as effective for showing specular detail.
What I will say that is that lack of detail likely more of a diffraction issue than an effect of the lighting itself. Macro-photography frequently calls for photographers to use very small apertures to maintain enough DOF to cover the subject.
When using Ringflash I have no problems seeing the facets of the eyes on insects:
Pentax K10D - Pentax FA*200mm f/4 ED Macro - Pentax AF160FC ringflash Originally posted by hangman43 Like I have said I have a ring flash and in the field the soft box yields better results a 6x7 soft box has much softer light than a ring flash and does bring out fine details that I miss with a ring flash.
Softboxes aren't the best for bringing out texture in a subject, they are great for specular and reflective objects (like the eyes of insects) - if you really want contrasty lighting using bare bulb flash is better for that because the smaller a light is the harder the shadows are - and this contrast can be used to great advantage by using the flash at hard angle relative to the subject.
