Originally posted by calsan Have you tried changing to a different type or brand of batteries? Different types of AAs have different voltages and current capacity, so they could drop below providing enough power for the zoom motor.
Failing that, the zoom motor could be dead or dying. But at least try a few different battery brands before jumping to that conclusion.
I tried a new set of energizers and a fully charges set NiMH no luck. Tried the flash on the *ist DL no luck, put it back on the K5 it worked
Only difference was this time the "Wide Angle Panel" was retracted. If I lift this the flash switches to manual zoom just as described in the
very fine print on page 21
Thanks
Paul
