pw confirmation message
Thank you for your inquiry. The short answer is yes! You'd be using something called "Relay Mode" to do that. I'd recommend the PlusX radios for this setup. Your setup would be this:
Your camera in your hands, with a PlusX set to Channel 1 in the hot shoe.
Any flash you want to fire with the camera in your hand set to Manual, and connected to a PlusX on Channel 1.
Your remote camera set to manual focus, with a PlusX set to Channel 1 in the top shoe, connected with a remote triggering cord (your exact model can be found here:
PocketWizard )
Your remote flash in manual mode that you wish to fire with your remote camera connected to a PlusX set to Channel 2.
When you fire the camera in your hand, it sends out a Channel 1 signal. This syncs any flashes set to Channel 1, and also triggers the remote camera. The camera's shutter opens and fires the radio in the top shoe again, which switches to Channel 2 and fires any flashes set to Channel 2.
