06-20-2013, 10:04 PM   #1
i83N's Avatar
Can somebody explain me difference between Slave and Servo modes on Metz flash
I updated my Metz 58 AF-1 digital firmware from 3.0 to 5.0, aded servo mode in flash functions.
Whats the difference between slave and servo modes?
06-20-2013, 10:25 PM   #2
Adinfinitum's Avatar
Slave supports PTTL optical - ie: the camera pre-flash sends the exposure info.
Servo is "dumb" slave - ie it the flash ignores the camera pre-flash and as such, the flash exposure must be set manually.
06-20-2013, 10:51 PM   #3
i83N's Avatar
QuoteOriginally posted by Adinfinitum Quote
what i actually thought
Thank you (:
06-20-2013, 11:56 PM - 1 Like   #4
maxfield_photo's Avatar
That's almost correct. Servo mode is "smart" slave mode because it ignores the preflash. "Dumb" slave mode is what you would get with a traditional optical slave, a simple photocell that sends a signal to fire every time it sees a pulse of light.
Dumb slave mode works great with manual flashes such as studio strobes, but a "smart" optical slave will sit there waiting for a second flash that isn't going to come. Unfortunately at this time, Metz only has the option for preflash suppression, so if you want to trigger your 58 optically with a manual flash, you will need to get a separate external optical slave, or another wireless receiver.
On the other hand if you want to trigger the Metz with an on-camera pTTL flash, you're in luck because you can do that now. Whereas before the flash gun would be fooled into firing too soon and therefore it would be in the processes of recycling when the exposure-making flash occurred.
06-21-2013, 01:24 AM   #5
i83N's Avatar
Thanks
"smart" slave is what i will certainly use in my work (:
flash, lighting, metz, modes, photo studio, servo, slave, strobist
Difference between Program and TAv mode on K7? Tonto Troubleshooting and Beginner Help 4 11-13-2011 05:03 PM
Wireless Servo Mode on Metz 58-AF2 teljalis Flashes, Lighting, and Studio 4 09-25-2011 10:35 PM
Difference between ME Super and ME Super SE JeffJS Pentax Film SLR Discussion 10 05-11-2010 07:23 PM
difference between flash compentsation and regular EV compensation? tram57 Pentax DSLR Discussion 8 03-05-2010 08:26 PM
difference between the automatic picture modes anyfoo Pentax DSLR Discussion 5 10-29-2007 07:58 PM
All times are GMT -7. The time now is 10:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
