What I meant was, you would probably trigger this with another manual flash on the K-30.
Also, according to our database, the flash can support 20 bursts/second, which may be fast enough to fire on both the pre-flash, and the main flash. For example, the AF 360 FGZ, in dumb slave mode, can keep up with the K-5's and K-01's on-board P-TTL. I wouldn't normally configure the AF 360 FGZ this way, since it supports P-TTL, but it was just an experiment. (More importantly, it can also keep up with the X-90's pre-flash which is
much faster that either the K-5 or K-01, because there is mirror or mechanical shutter.)
Of course, to "double tap" the external flash, it has to be on some reduced power setting. The P-TTL flash will meter itself and adjust the overall lighting accordingly. The off-camera flash will be at a fixed power output based on what you set. Just make sure the off-camera flash doesn't overpower your composition. Therefore, chances are, you would likely use a fractional power setting anyhow.
As someone commented elsewhere, there are some add-on optical triggers that can be programmed to ignore a pre-flash, which would let you trigger it with the on-board P-TTL, while using the off-camera unit at full power if desired. Not sure if the AF 500FTZ supports natively supports such a smart optical trigger mode; I would tend to doubt it, since it was from the pre-P-TTL era to begin with,
