Originally posted by skyer It's a bit confusing to me. How can I switch to 1/180 from 1/160 if one turn of the wheel selects 1/200, not 1/180 (in P-TTLL HSS). If my flash is in ordinary P-TTL mode, I can easily select 1/180.
What Class A was suggesting (as I understand) is to get to 1/180 you have to use the mode dial and use the "X" mode where the shutter speed is always 1/180
When you are in PTTL or any other mode (except for PTTL HSS) the top shutter speed is limited by 1/180, so in any mode on the camera after 1/160, 1/180 will appear (rather than 1/200). (Well to be precise when the meeter is not active the LCD screen may show 1/200 however as soon as you activate the meeter it goes back to 1/180)
In PTTL HSS mode however you can select any shutter speed you want in M, Tv or TAv modes, thus the normal sequence is valid (i.e 1/160 then 1/200 ...) thus to get 1/180 in PTTL HSS mode you need to switch to the "X" mode on the camera, you can also get 1/180 if you go to any mode where the shutter speed is selected automatically by the camera.
