Originally posted by Fototim Hm. Are you saying that I need to use a P-TTL compatible flash as master and another P-TTL flash as slave? That hoovers.
Does this mean that I can't use HSS i manual mode?
Please tell me that this is incorrect.
So sorry, you got it correct. High Speed Sync requires the flash to strobe as the focal plane shutter moves across the sensor gate as a slit narrower than the gate itself. The timing of these multiple flashes is as you can imagine, rather critical, and P-TTL provides the timing. Even if you do it with a wired off camera flash rather than wirelessly, you still need P-TTL to control the timing.
There are multiple threads here describing how HSS works so I am not going to repeat all that. Bottom line, no manual HSS - it simply isn't possible.
I don't know your intended use, but given how HSS works, its best use is for fill flash in bright ambient lighting conditions. Contrary to what a lot of people might think, it is really not appropriate for freezing action.
