Originally posted by dmbaile2 Just to confirm, are the P-TTL flashes the only one that support shots faster than a 160 shutter?
When you need a TTL controlled flash on your Pentax, it should support P-TTL anyway. But not all of them support "high speed sync" or "second curtain sync". You could look at B+H for more info on P-TTL compatible flash units:
On Camera Flashes | B&H Photo Video
I chose the Metz MB 44 AF-1 for my K-x, and it works very good in P-TTL mode. Neither "high speed sync" or "second curtain sync", but tilt/swivel and a build-in bounce-card. I recommend you get a flash unit with enough power, which you will need if you use bouncing light. I use my flash often at parties with bouncing against ceiling, using the bounce-card or a third-party diffusor cap. Having enough power also means a short time to recharge. I found my Metz to have sufficient power and I'm very happy with the results.
