Since my Metz 48AF-1 does not support wireless HSS master function but can only be slave I consulted the ultimate
Pentax PTT feature comparison and after shopping online found used Metz 52AF-1 at Amazon marketplace. All the reviews confirmed it does work as wireless HSS master so I ordered it. When the package arrived however I discovered I received top of the line
Metz 58 AF-2 instead. Nice surprise
The only problem is it worked as wireless master but not in HSS mode
Hmm... looks like seller misrepresented the unit. Should I return it and keep shopping? But after realizing all the additional features this flash had over my Metz 48 I was really hesitant to return it considering I got it at the price of lower model.
Then I found
this thread describing I can use Metz servo mode to accomplish my goal of using off-camera flash at faster than 1/180s. I'd reverse the roles and use my existing Metz 48 in the hot-shoe in regular HSS mode (not wireless) which would enable fast shutter speeds on the camera and send light impulses to trigger (more powerful) Metz 58 off-camera.
I was not sure if Aokatec triggers (which is light->radio->light proxy in essence) would also work to transmit visible light spectrum so I tried it and it worked same way as with infra-red putting IR transmitter over same sensor.
To summarize, with
two external flash units,
Aokatec transmitters and
triple-flash hot shoe adapter I have many options and have tested some:
1. Built-in popup flash controls two off-camera units with P-TTL using IR.
No HSS in this mode range is short. Good enough for dark in-doors with shutter speeds slower than 1/180s.
2. Buil-in popup flash controls two off-camera units with P-TTL over radio.
Long range but still limited to 1/180s or slower.
3. Camera hot-shoe triggers one or more off-camera flash units using Aokatec manual mode.
No PTTL, no HSS - full manual mode. Any flash can be used in this configuration. Aokatec TX unit is mounted in the camera hot-shoe and RX unit is connected to
triple-flash hot shoe adapter by 3.5mm stereo cable.
Simple setup just like most other brand of radio trigger.
Interesting observation: with TX unit in hot-shoe camera does not register flash present but closes the circuit up to 1/180s speed.
4. HSS (without P-TTL) using simple optical wireless.
One HSS flash (does not have to be Metz) is mounted in camera hot-shoe. Off-camera Metz (can be multiple) is triggered remotely by light impulse. In Servo mode it ignores pre-flash and fires with actual flash.
Off-camera flash power can only be adjusted manually but it has to be set at 1/1 (full) as that's the only level where flash it long enough (1/125s) for complete frame coverage. Thus to balance ambient and flash one has to experiment with distance to object and/or flash zoom setting.
It turned out the range of optical wireless is much more useful than IR.
I positioned slave flash so it's sensor would face my camera-mounted flash. Even without swiveling the head of camera-mounted unit I had enough flexibility of pointing my camera at the objects and the light would still reliably trigger at 30ft (from the other side of the road). All this in direct sun light.
The range was sufficient for my needs and I used this today during bike race shootout.
I cropped this shot to show actual flash placement so you can judge the range it was effective at.
I enabled secondary flash tube on Metz 58 at 1/4 power just so I could see it as confirmation off-camera flash fired (primary bulb in a head was facing away from me towards the riders).
As you can see from the shadows the flash was directly opposing (morning) sun but was strong enough to lit up the face of even 3d rider (about 4 bike lengths from the flash).
While in theory I loose PTTL control in HSS mode using Servo slave mode but in practice it worked out pretty well today even without extending the range by Aokatec product thus simplifying setup.
5. HSS (without P-TTL) using Aokatec radio wireless extension.
Same as option #4 but extending the range with Aokatec TX and RX units.
The hookups look like this:
I was able to trigger off-camera flash at much longer distance over radio
across my entire back-yard Observation about Aokatec product behavior
One important glitch I found with Aokatec triggers when using Servo mode (as opposed to regular PTTL) was unpredictable false triggering of off-camera flash. At random times RX unit would trigger the off-camera flash to fire without any command. Aside from wasting the battery it also means lost 4-5s for flash recycle (since we must use full power to make HSS work).
I troubleshooted this issue and found that RX unit when set in Auto mode even by itself (i.e. TX unit is off, nothing is hooked up to RX) would randomly start blinking red LED which means it thinks it received radio signal to trigger.
Interestingly off-camera flash is configured as PTTL slave (option #2) this does not produce false flashes (but I noticed system becomes unresponsive during such bursts of false triggering and misfires when I want it to).
When off-camera flash is in Servo mode this behavior leads to wasted flashes.
When Aokatec set to manual mode (option #3) I did not observe any such false triggering (no red LED when not fired).
I emailed Aokatec support about this.
