ok first remember that for manual flash the shutter speed controls the amount of ambient light allowed in to the exposure and the apature the amount of flash. Now I know that hard to understand so try this
put you camera on manual; set iso to 100; set shutter speed to 1/60; set your aperture to f5.6
now switch you flash on to manual, set it on full power and attach all you trigger kit and put the flash about 9ft from the subject and take a image you should be in the ball park with exposure,
if you adjust your APERTURE ONLY you will see the flash component of the image alter but not the non flashed parts of the image.
Why did that happen? because you altered the amount of flash made light that you allowed into the sensor.
Once you are happy with the flash component now change ONLY THE SHUTTER to 1/180 or 1/160 which ever you can BUT NOT FASTER then 1/180 you will see the non flashed parts go dark but not the flashed parts.
why did that happen? because you made the shutter faster and decreased the amount of ambient light getting in.
so on your meter if you set a shutter speed and the iso the meter only measures the flash but tells you for that shutter and iso what will give you a good exposure. If you set all three as per the meter on your camera and you will get a well exposed image.
remember it's the flash to subject that matters, as long as that is constant you can go where you like.with the camera.
Now for pttl using the Aokatec at a wedding i don't want to guess or mess with a meter so since i like using off camera flash I can get pttl consistently with out worrying about distances or bright light wrecking the infared signal that works the Pentax slave system.
Hope that helps have a look at
Collection: Engagement Shoots with the exception of the classic folder these are all off camera 1 flash, metered once at the beginning of a set and that's it, once the light is placed at the same distance nothing else changes no mater where we move to
