Originally posted by HermanLee I am also thinking to get a flash for my K100D.
Sorry, I don't mean to hijack the thread, but I just want to know if the wireless function of those flashes (Pentax/Metz//Sigma) will work with K100D?
Matt what do you think about the Metz 48 AF-1 performance?
I read from some threads here that the max sync speed is only 1/125.
Also some people say that it can't be used as slave directly w/Pentax or need separate module (maybe I'm wrong about this)?
I'm quite happy with the performance. Works well, puts out all the light I need in most situations, and does a relatively decent job of getting the exposure right with P-TTL. High speed sync and wireless modes work as they should.
The sync speed is a factor of the camera body, not the flash. Here's the deal with with the 1/125th number you've seen quoted, investigated by Richard Day:
https://www.pentaxforums.com/forums/155766-post7.html
In short, the flash can only do full power at longer durations. But it's also the case with Pentax flashes in basically exactly the same way.
You need a separate module with some of the Metz lines, but the 48 AF-1 and 58 AF-1 are "dedicated" units which just work.
That said, you can't use the internal flash of the K100D as a controller — you need the K10D or K20D for that. Or, you can use an AF360FGZ or AF540FGZ or Metz 58 AF-1 (but not 48 AF-1) or — I think, but not tested — the Sigma flash (probably only the Super version?).
