Originally posted by alamo5000 I googled 'flash trigger' and that right there looks 'exactly' what I would be looking for (in addition to the flash itself)....is it common to use more than one flash? So if I got the cactus thing is it 'normal' to use more than one flash on a single shoot/shot?
There's really no 'normal'
. You can do an awful lot with just one flash or just one flash + ambient, but sometimes you want more. Starting with one is probably fine unless you have specific things you want to do in mind. A real basic kit would be a flash that you can control manually and a pair of triggers. That's all you really need to get going with off camera stuff. Bonus if the triggers can be mounted to a tripod you already own or in a friends hand
Originally posted by alamo5000 Also how can I tell if the flash is compatible with the cactus trigger or something similar?
The usual stopper is an older flash with a huge trigger voltage on remote triggers that can't handle it. Any new flash should be no problem, you can check out
Photo Strobe Trigger Voltages if you're looking at used ones.
Voltage aside, most of the cheaper triggers will take any hotshoe flash ('hotshoe' refers to the bits that attach the flash to a camera body). Some will also have various cord options for more versatility.
Originally posted by alamo5000 What is the differences between a 'full manual' flash and an 'auto flash'?
"Full manual" means you physically set the power level, either switches or pushing buttons. "Auto flash" comes in several varieties, Auto-Thyristor or TTL or pTTL for example, where the flash or the flash+camera will make some decisions about power outputs (possibly with some input from you similar to the cameras normal exposure compensation). If you're going off camera, a flash with manual controls is the way to go if you're on a budget. Most modern flashes will include manual controls, but there are definitely some older flashes that don't.
I'd suggest you check out
Strobist: Lighting 101, it will answer many questions and point out some basic starter gear. And I also quite enjoyed
Light Science and Magic: An Introduction to Photographic Lighting: Fil Hunter, Steven Biver, Paul Fuqua: 9780240812250: Amazon.com: Books for a general read on lighting. There are literally thousands of other learning resources though (most importantly going out and practicing once you get a basic kit
IMO, learning about setting up artificial lighting has also helped me 'see' ambient light much better.
