I have the following hybrid setup and I always & only use manual exposure:
Two Pentax 540 AF flashes - Bought 1 new ( 400 USD) & 1 Used ( 250 USD). I use two cameras at events ( 1 wide & 1 longer lens ) so a flash on each with the "
black foamy thing" . Cameras are manual, flashes are set for P-TTL, usually - 1 EV. I also use HSS mode to fill in bright sun. Sometimes I use them in manual mode. The site where you read about the black foamy thing is a very good place to learn about flash
One Yongnuo yn-560 II Flash. This was about 60 USD and is all manual exposure. If I never used P TTL or HSS, I would only buy these. They are about as powerful as the Pentax 540's, swivel & tilt. I bought this as an extra flash for studio work.
All the flashes use 4 AA's I use Powerex batteries & charger, many swear by Sanyo Eneloops.
I have used all 3 with multiple sets of
Cowboy Studio aka PT-04 wireless transmitters & receivers, direct purchase or Amazon. These are throw away cheap ( like that drawer of cellphones & remotes) and they work. About 20 bucks a set. I carry 4 sets. The receivers use AAA's ( I use good alkalines) and the transmitter uses a 23A 12 Volt found at any drug or office supply store.
The transmitter goes on the camera hot shoe. The receivers mount on the flash hot shoes or by the sync port which the Youngnou can use. The Pentax flashes have a proprietary sync port so the hot shoe is the way to go.
These units only fire the flash, no other control. Pentax does not offer the wireless capability that Canon & Nikon do.
I have used the transmitter to fire 3 flashes. I use the receivers on my Alien Bee monolights. I have used the monolights & flash together fired by 1 trigger.
The Pocket Wizards that send I-TTL & E-TTl info for Canon & Nikon aren't available for Pentax. Pentax does not currently have PTTL wireless except its own optical capability.
Youngnuo makes flashes that work like Canon & Nikon TTL flashes. Not available for Pentax
