10-03-2013, 09:38 PM   #1
Sigma EF-610 Super DG problems
I think my flash is boned.
I put it on wireless mode, set everything up and correctly, stick the flash on a tripod. It will fire a couple of times, and then stop. Actually, if I wait a while before taking a shot it won't fire at all. It's like it's forgetting the setup after a VERY short while. Like, 20 seconds or so. The only way to get it to work again is to put the flash back on the camera, half-press the shutter button, and then put the flash back on the tripod.
Batteries are nice and fresh, so it's not that.
Is my flash hosed? Or am I missing something?
Charles.
10-06-2013, 05:13 PM   #2
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
Charles- I have never experienced this with my Sigma EF-610DG Super. If your flash works correctly, and with no changes to the setup, it doesn't, I'd say there is a problem. The ONLY thing I can think of is if 'couple of times' is more like a couple dozen shots at full output. The flash may be shutting down due to thermal issues. See pages 16-17 in the manual.
10-07-2013, 06:19 AM   #3
The flash always works when attached to the hot shoe.
In Wireless PTT mode, it's time-dependent. If I set it up, and immediately take a shot, it will work for two or three shots. If I wait more than say 10 seconds, it will stop working. This is only in wireless mode.
It always fires when set up as slave, but when set up with PTT control using a pre-flash to communicate, it is not working correctly.
Charles.
10-07-2013, 07:39 AM   #4
JimJohnson's Avatar
Sounds like your flash is defective. I probably use my 610 more often as a wireless P-TTL triggered by my camera's built-in flash than attached to the hotshoe. I've never experienced your issue.
11-02-2013, 08:40 PM   #5
It sounds like the circuit board is damaged. Mine would charge, but not fire. Learned the bulb blew and damaged the circuit board. Not exactly the same issues, but there's so few parts in these things.
I had to send mine in for repair last year. Took about 4 weeks to get it back during the Christmas holiday season. Had to buy another Sigma flash in the interim to keep going. The service center was on holiday between Christmas and New Years. Wish you luck in getting it working.
11-03-2013, 06:35 AM   #6
GeneV's Avatar
Sigma has a lot of features at a great price, but it does not seem to be well made. I had a similar issue which turned out to the the switch on the wide angle diffuser. It finally came off in my hands when I was fiddling with it. I shoved it back in never to be used (or usable) again. The good news is that the wireless P-TTL works much more reliably now.
fire, flash, lighting, photo studio, strobist, tripod
Urgent - Sigma EF-610 DG ST Super Compatibility redimp Pentax K-30 & K-50 14 01-28-2015 10:28 PM
K-30 with Sigma EF-610 DG Super flash CWuestefeld Pentax K-30 & K-50 3 03-11-2013 12:11 PM
Sigma EF-610 DG Super randomly stops firing ? Isnwm Troubleshooting and Beginner Help 2 08-28-2012 07:06 PM
Sigma EF-610 DG Super Timing issue shaunscott Flashes, Lighting, and Studio 4 07-17-2012 09:18 AM
For Sale - Sold: Sigma ef-610 dg super flash for pentax vario Sold Items 2 12-30-2011 01:44 PM
All times are GMT -7. The time now is 04:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
