Originally posted by jrcastillo any flash that anyone can recommend that supports HSS and that is not $500?
I mean, whats the best bang for my bucks?
thanks!
The AF 360FGZ supports HSS and it "only" costs $250. Not sure if you were being serious about the $500 limit, but the normal price on the AF 540FGZ is still only $400, still within your budget. There are plenty of third-party options under $500 which support P-TTL, just make sure the specs say it actually supports HSS.
Just a brief mention, that depending on what you want to do, you could also pick up another non-DSLR camera that supports higher native sync speeds, such as the Q10, which can do 1/2000 and is currently going for $324 with a compatible (leaf-shutter) lens. That would work directly with your YN-560 III just fine at the higher speeds, even without HSS protocol support.
