Yesterday, I made DIY slave flash as seen on Carl Vogt webpage.
It uses on camera flash to trigger the slave and it works (triggers) quickly and consistently
BUT, when I tried to test it properly there was NO flash on the photos!
I'll clarify: 1. I press button (can't remember the exact term but it's button alright)
2. Shutter clicks and built in flash fires
3. Slave fires (at least to my eyes) completely instantly
4. On the resulting foto you can see light from the built in flash but no light from the slave (even when camera is pointed straight to the slave flash lamp)
So I tried to lenghten the exposure time to compensate for the lag in the circuit - nothing!
To make sure - slave IS FIRING - my sore eyes are proof of that.
I also tried to change built in flash to different modes (wireles, slow etc) - nothing.
Only time when I managed to capture the flash was when I combined very long exposure time (10 sec) with rear curtain mode for the built in flash. On that (so far unique) occasion, both flashes fired twice - on the beggining and the end of the exposure (slave had enough time to charge because of the 10 sec exposure), and that SECOND flash was captured in the photo.
So, what that gives me?
Is it posible that built in flash fires BEFORE shutter curtain actually opens and then continues to emit light through the exposure but slave flash (old Braun model) has much shorter flash duration and finishes before curtain even starts to open?
So far, that was only reasonable explanation I can think of.
Sorry for the longish post.
