12-04-2013, 02:47 PM   #1
synnyster's Avatar
Beginner Studio Lighting Kit Suggestions
Hi All,
I'm about to have a baby and want to acquire a budget studio lighting kit to take photos when the time comes. I currently have a Pentax K-5 with a Metz AF-1 flash. I also have 2 Loadstone 86" light stands, one with a hotshoe adapter for my Metz. What do you all suggest I get to compliment my setup so I can get some good quality "studio" shots? I've been looking online and there are a few light kits I see that are affordable on Amazon (< $250). I'd like to keep the budget around or under $200.
From what I can tell, I need a backdrop kit, perhaps a softbox, and some umbrellas. Do I need a constant light? Do I need flash triggers? Should I get a cheapo flash as well? Any suggestions would be great.
12-04-2013, 03:22 PM   #2
Best $110 you'll ever spend on studio lighting
creativeLIVE: Studio Lighting with Zack Arias
You can have the gear, but it doesn't mean anything without the knowledge and skills behind it. More often than not, the ideal kit comes after attaining the knowledge of your actual needs
12-04-2013, 04:06 PM   #3
Light modifiers! If you don't want to buy your studio strobes twice, get a system that has plenty of accessories and light modifiers available for it to fit the strobes.
12-04-2013, 04:33 PM   #4
synnyster's Avatar
QuoteOriginally posted by adpo Quote
Thanks for the suggestion. I still need the gear to practice with. Once I acquire it I will be reading up on lighting techniques etc.
12-04-2013, 04:46 PM   #6
QuoteOriginally posted by synnyster Quote
What do you think "studio shots" look like?
I'm assuming you mean muslin backgrounds? For typical family photos, you usually need 3 lights, and props.
For the $200 budget, you probably won't get better than what you pointed out
I'd avoid constant lights but kids are usually twitchy so you'll get motion blur.
Studio strobes should have 250W modeling lamps so you can aim them properly, though you could do it w/ speedlights.
Look at Strobist to learn how to light.
12-04-2013, 06:44 PM   #7
Eric Auer's Avatar
Clip lights from Home depot, A bucket of bulbs from 15w to 100w. Clothes pins, Parchment Paper and a a clean white wall.
The rest is technique.
12-04-2013, 08:10 PM   #8
What's the parchment for?
12-04-2013, 09:00 PM   #9
Eric Auer's Avatar
QuoteOriginally posted by dansamy Quote
Use as reflectors, diffusers. Pin loosely over clip lights. Watch carefully as you dont want them to go up in fire.
Play with the paper, Hang them loose, Turn in to cones etc.
Just have fun.
12-04-2013, 09:09 PM   #10
Yeah, almost as soon as I asked, I started thinking of what you COULD do with parchment. I suppose one could also make reflectors with some household materials also.
12-04-2013, 10:09 PM   #11
Eric Auer's Avatar
Yeah, But these are hard to beat.
HDX 150-Watt Incandescent Clamp Light-CE-300PDQ at The Home Depot
Just dont overload your circuits by plugging in too many on the same leg.
12-05-2013, 08:42 AM   #12
for reflectors, you can use disposable aluminum baking pans as well.
Cheap poster boards from Michael's or some other crafts store works well for reflectors too...they have gold, white, etc.
It's really about light. Just make sure to have enough so your shutter speed doesn't drop too low if you're using continuous light...
But the question is still what do "studio shots" mean to the OP. An example would help us figure out what's really needed...
12-05-2013, 02:07 PM   #13
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
Constant lighting (typically done with 6500K fluorescent bulbs these days) makes it easy to get the desired lighting effect. The downside is even with some pretty high wattage bulbs (for fluorescent lights), you will likely find your shutter speeds are lower than what you would like for an active subject. The flip side is that lamp holders can be inexpensively converted into speedlight (flash) holders by the time the baby is more active and by then you should know what does and doesn't work for you.
12-05-2013, 05:42 PM   #14
I've heard different ideas as to wether flash is good for new borns or only natural light should be used. Does anyone have a definative answer?
Thanks.
Tuggie76
12-05-2013, 05:55 PM   #15
Newborns have acrocyanotic skin in the first couple of days due to the circulatory system changes that occur as a result of transition to ex-utero life. Their extremities are prone to bluish-purplish mottling, exacerbated by a cool room temperature. It's important to have a warm room if you want any of those naked or diapered baby photos. Too much light might also give you some translucency issues depending on the baby.
And not every baby is cute & cherubic & photogenic. Some babies you'll have to work hard to get a "cute" picture.
beginner studio, budget, flash, kit, light, lighting, metz, photo studio, strobist, studio, studio lighting kit, suggestions
Studio Lighting Kit - Chinese or Branded? voyager13 Troubleshooting and Beginner Help 5 06-02-2013 07:01 PM
Beginner's Lens suggestions kcisonfire Troubleshooting and Beginner Help 15 04-16-2012 09:34 PM
Studio lighting suggestions coachteeter Troubleshooting and Beginner Help 2 07-25-2010 03:16 PM
Help/Suggestions for Lighting kit wa5am Pentax Camera and Field Accessories 4 11-25-2008 04:42 AM
For Sale - Sold: Studio Lighting Stand Kit Buddha Jones Sold Items 6 08-20-2008 04:45 PM
All times are GMT -7. The time now is 02:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
