Originally posted by Driline Thanks for the help. So really this chart is not really of any use?
It is useful if you're a novice like me!
I do find that I'm using it less as I get the feel for where to set the flash and exposure, but I made it to help me get started with a shot similar to what you are doing. Using your example, you say you want to use f/5.6 and ISO 100. In order to get a wide beam to match the DA21, you want to set the flash zoom to 28mm as suggested. If you are using on-camera flash with no umbrellas or soft-boxes at a distance from the group of 15 feet, then we can read the chart to know that the flash will likely need to be set at full power (because the full power will light up the scene from a distance 17.5 feet which is close enough). If it's too bright, try one step down from full power, or put a paper tissue in front of the lens. The downside is that the flash will take a while to power up so you have to have everybody stay put if you want to try multiple shots.
With that as a starting point, here a few suggestions from what I have learned using a similar setup.
First, I would recommend that you go to f/8 to be sure that everyone in the group is in focus. That reduces your light by half. If you want to keep everything else the same, simply go to ISO 200.
Second, a single on-camera flash will be hard light and you will get red eye and a snapshot look. If possible, try to use off-camera with an umbrella (or hang a thin white sheet in front of the flash). So let's assume you can put the off-camera flash on a stand off-center from the camera with an umbrella. The umbrella will lower the light about a stop, so now you would need to move the stand closer to the group to about 12 feet away to keep the same settings.
Another option would be to bounce off the back wall (if that's possible) or that nice side wall that I see. In this case you will need to add 2-4 stops depending on how reflective the wall is and how far from the flash it is. Also note that this will affect your white balance.
Finally, I would also suggest using two flashes with a group this size to get more even light across the group. Otherwise you will likely have part of the group too bright and part too dark. In this case both flashes will add to the light, so you should be able to go back a stop to ISO 100, f/8. Better yet, bounce two flashes off side walls and up the ISO until the exposure is correct.
Best wishes,
Kevin
