First of all, greetings to pentax community, and excuse my English!
I've been following these forums for a very long time, after I bought my first DSLR, pentax k-x, and today when I want to log in and ask these questions, it was surprise to me that i haven't even been registered.
Today I'm still with k-x, great 18-55 kit lens (for the budget), old pentax extremely sharp 50 1.7 manual lens, sharp and great 55-300.
I'll probably upgrade body to k-5 II, but not any time soon, and buy 10-20 sigma lens, but all these doesn't matter much for this conversation.
I'm not beginner in the photography, but I'm completely beginner in flash/strobes, studio lighting, and need your advice.
I'll probably shoot portraits, full and half body figures, and some small objects, mostly over white backgrounds, maybe sometimes gray or black.
few things i know is that minimum of 3 light sources, 2-3 stands, rolling paper (white, grey, black) and that i would love to use HSS so maybe flashes (not strobes) are my choice?
my budget is from 400 to 500 $, maybe I can go more, but not too much.
so questions are:
1. is k-x capable of HSS, is it wireless HSS and if it isn't what kind of HSS is it?
2. if HSS is flash, not camera based, what are the cheapest flashes with that options? and how to trigger it with k-x?
3. i'm not sure what is p-ttl or ttl, but I'm good with manually setting flashes if those options are something that automatically do that, and because of that flash prices go much higher
4. strobes cannot do high speed sync?
5. softboxes or umbrellas? or both? short explain why please?
6. if anyone think that I would first need to upgrade my k-x, please say so. For what I shoot now, I'm very satisfied, but never done studio photography.
7. if I need to put master flash on camera hot shoe, what are best options not to flash harshly and directly to the subject?
8. what radio triggers work good with k-x and 2-3 flashes?
9. if I use built in pop-up flash for trigger, will it fire or just trigger those other flashes?
10. for HSS, is it possible to put max sync speed (1/180) on camera but just to light with flash for 1/500-1000 or shorter duration? will effect be the same?
11. if 10th question is answered "yes", i suspect flash power will be much lower, so it will be harder to light everything correctly?
Thank you very much for your patience and answers
Best regards
Nikola
