Hi there! I recently bought a Yongnuo 560 III and I am very happy with it. But there is a problem with the slave modes and I think the problems might be with the camera because I have experienced them with other flashes. The thing is that sometimes slave mode just doesn't work the way it should be. Sometimes the flash just stops lighting the frame even if I haven't changed any of the settings. Just I shoot, everything is ok, then the very next moment (I've waited for the flash to recharge), it flashes but the picture looks dark. I shoot in S2 mode, the settings in the camera are Wireless, pop up flash set to controller. Other problem is that I can't shoot with power 1/2 or more. I don't know why is that, the flash fires but it just doesn't light the frame. I have a Lumix Fz100 camera with a high speed video and I shot to see what the thing is. What I found is in wireless mode the pop up fires three flashes - preflash and two others (or two preflashes?). I have no idea why that is but that might be the problem because when i shoot in normal mode pop up everything works just fine, but i don't want the pop up in the frame. I can use some kind of card to hide the pop up (or bounce it towards the Yn) but I would be happy if I make the wireless mode work.
Cheers!
