Originally posted by Scootatheschool1990 Okay so does this differ from TTL? Which is better?
As I understand the matter, with auto-thyristor, you have to dial in the aperture, shutter speed, and ISO, and then the flash unit sets the correct amount of light for that configuration. With TTL, the camera and flash coordinate to determine your preset or green mode setting, and adjust the flash light output accordingly. Therefore, TTL is a more automated system than the older auto-thyristor. My auto-thyristor setup with the Sunpak 522 yields perfect or near perfect exposures every time regardless of the type of lens being used, even old legacy screw-mounted lenses. I am not quite sure how Pentax TTL or PTTL do with the legacy glass since the camera cannot read the aperture setting.
