I never liked using flash equipment during the many years that I shot 35mm and rarely used it. That set the stage for not learning much about it. Lately, I've found myself in situations - mostly shooting family type stuff (six grandchildren ages 2-10) - where I need to use a flash. The built-in flash is pretty much useless, based on results.
I need a unit that is powerful and flexible enough to handle most normal "people in interiors" (for lack of a better way to describe it) situations. I assume that it should also recycle quickly. I have both a K10D and a DS; can I get something that can be used on both cameras? If not, I'll use it on the K10D. Also, if I have a decent flash I might try using it for macro work (infrequently).
The really irrational part of this, is that I hate using something that sticks up from the hot shoe. The few times that I used flash equipment with my 35mm cameras, it was one that mounted on a bracket (attached to the tripod socket;still have it) that held it to the side of the camera; I'd like to stay with that type of setup.
Since I don't know much/anything about flash, looking at various equipment descriptions on a web site like B&H just gets confusing. As far as cost goes, I would like to keep it under $500 in total. Hope that someone can give some direction here.
Thanks.
