Originally posted by bdery But we were not discussing Cactus' products at this time.
I agree that off-topic discussions should be avoided in general, but overall I believe when it comes to discussing gear choices it is beneficial to everyone if alternatives are discussed.
The OP initially asked for experiences with the V850 but also specifically added "
...or can someone recommend another product?". Later on, howieb101 mentioned that he is considering replacing his Nikon SB24s and Nikon SB25s with V850 and I then commented that he could alternatively consider keeping his Nikon flashes and still remote control their power with a Cactus V6.
I believe this is what a forum is for, to discuss alternatives, not focus on a particular brand.
N.B., I'd very much welcome your participation in "my"
Cactus RF60 and
Cactus V6 threads.
Originally posted by bdery The V850 and RF60 are different flashes. The RF60 has more features, the V850 faster performances and longer battery life.
I fully agree and that's why I said at least twice in this thread that the V850 is a very attractive flash. It is also why in my RF60 review I wrote "
If one is after the fastest recycle times and best stamina in a compact package, the Godox V850 is the best choice. " As you do, I realise that different users have different needs and that there is no one "best" equipment for everyone. We agree, "
choice is good!".
Originally posted by bdery I think your comparison is informative but shows some bias towards one of the flashes...
First, I admit that having beta-tested both RF60 and V6, I naturally have an initial closer affinity to them because I was able to experience their pros first hand. I also admit that my reviews try to convey my enthusiasm to others. I think that's what most people do; if they make a good find, they share it with others.
However, I am genuinely interested in learning where you think my descriptions are "biased". It is my aim to fairly describe the pros and cons of each product so that the reader can make up their own mind by contemplating which criteria are more important to them. If I have forgotten a Cactus-"Cons" or a Godox-"Pro", please let me know.
I'm not here to promote Cactus gear. If I point people to my reviews and argue the benefits of the system it is because I believe that it could be a very good choice for them too. But I also point out pros and capabilities of other systems, e.g., as in this thread the ability to
accelerate the adjustments on the Godox remote.
Originally posted by bdery that why in my upcoming review I set both flashes at 50mm and compared the histograms of a fixed scene. That's the most neutral test I cuold come up with.
I think that should work well. A more scientific approach would have been to use a uniform surface as a irregular scene could favour one beam pattern over the other. However, I don't think the difference will matter, in particular as most modern flashes in a certain class are really close in their output.
Also, in the past I would have thought the difference between for instance GN 50.5 and GN 60 is significant, but it really boils down to only half a stop more light. I don't think that amount would get anyone out of deep trouble.
Originally posted by bdery Usability : I disagree.
That surprises me. Have you read my
Cactus V6 review?
How can you -- on a Godox FT16s transmitter --
- see all power levels at once
- see which group is active at once
- quickly turn off one group to see the overall effect without that group contributing
- very quickly change the power level (the V6 uses a dial instead of buttons and has an "adjustment acclerator" mode)
- quickly establish any potential subgroup combination, without having to re-establish power levels from memory
- change the power level of all groups at the same time by a specific amount in order to raise the overall brightness
- use multiple flashes with different maximum output wihout having to manually calculate what power fraction is the correct one for each
- choose a light level granularity from 1/10, 1/3, or 1/2 stops
- change the group of a receiver by pressing one of four buttons
- change the channel without dealing with DIP switches
I haven't used the Godox FT16s transmitter myself, so it may support any of the above V6 virtues in ways that are not known to me; please let me know if this is the case.
Originally posted by bdery Extra features : I agree. the question is whether someone wants or needs these features. If the answer is yes, then the best choice is obvious. If the answer is no, then the choice is also obvious.
I don't see why the answer would be "obvious" in either case.
It is always an overall trade-off analysis, isn't it?
If you want the additional V6 features but the Godox battery stamina without adding a battery pack to your gear then I don't know whether the choice is obvious. BTW, the V6 can control the Godox V860C, so there is a way to combine both worlds, but then the V860C has some disadvantages compared to the V850, so it remains difficult.
Originally posted by bdery That's because of the nature of flash tubes, no way around it.
There is a way around it demonstrated by the Witstro AD180/360.
Much more expensive, but the power of the battery and the performance of the tube is a better fit.
Originally posted by bdery Still, the battery itself does not get as warm as a set of AAs, so overheat because of the batteries is less likely to occur.
No, but to the best of my knowledge overheating of batteries isn't the problem. It is the heat building up in the flash head that makes manufacturers throttle the power after a while in order to avoid melting of the Fresnel lens and to increase the longevity of the tube.
Originally posted by bdery The main advantage of the V850, which is hard to apperciate until you use it, is that it's ALWAYS ready to fire (almost). If you use it at 1/2 power or lower, then you can litterally shoot without worrying about your flashes being ready.
That's the same with the RF60 (and other similar flashes), though. You couldn't rattle off 5fps with them at 1/2, but two shots per second shouldn't be a problem.
Perhaps let me close by explaining why I may have appeared to be a bit too eagerly to point to the RF60 as V850 alternatives: Some people (not you) seem to believe that a Li-Ion powered flash does not leave any room for any other flash powered with conventional AA anymore.I want to counteract that attitude by pointing out that there are criteria other than battery handling and stamina and recycling rates. But surely, if battery power galore in a small package is what you want, I don't think there is a better choice than the Godox at the moment.
