02-25-2014, 10:08 AM   #1
Using a softbox - help
So I picked up one of these fabric, spring loaded softboxes. Used it by the window to take some pics of lenses for sale - seemed to work OK. But I would be grateful for pointers/links on using this properly.
And for bonus points: how to twist/fold it up again to 1/4 size so it fits in its wee black wallet!
02-25-2014, 01:08 PM   #2
Bob from Aus's Avatar
Do you have something else that is round, twists and folds? I find by practicing packing my round reflector a few times helps me to twist my large softbox. I purchased mine via mail order and didn't realize just how big and difficult is was. I would have been better buying a much smaller one. I am reluctant to use mine in case I can't get it back together in its bag. So the problem isn't you.
I think the idea is to have some strong lighting source on the outside be it lights or a couple of flash guns being wirelessly triggered. I suspect it works equally well if you have the camera on a tripod.
Best of luck getting back in its bag other wise behind a couch or under a bed might have to do.
02-25-2014, 01:18 PM - 2 Likes   #3
mrNewt's Avatar
That's more of a portable lightbox instead of softbox.
A lightbox is ... well ... a box where you put your product in and take pictures of it - that specific one you have helps eliminating the sharp corners and gives nice continuous shadows.
These type of boxes are meant to be used with studio lights or speedlights. Won't give good results if just used outside in the sun.
How to use it... here are some videos on how others are using it.
Even though the boxes do not look the same, they can be used in similar ways without any issues.
How to bend it... well, usually you colapse the thing and then grab from two ends and just twist it in different directions.
It will start to twist into itself... needs some practice with that. Something like this:
flash, lighting, photo studio, sofbox, strobist, use
Help: Using a Yonguo 460-II or 560-II with a KX dmfw Flashes, Lighting, and Studio 18 01-28-2013 09:27 AM
Help - any idea why there would be oversaturation using a manual lens? mephistophelean Pentax K-r 23 09-09-2012 06:34 PM
Help using A 50 1.4 Seafood Pentax SLR Lens Discussion 5 06-29-2010 04:54 AM
Using a DSLR (more specifically K200D) HELP!?! khaz0r Troubleshooting and Beginner Help 17 10-31-2009 03:59 PM
Help needed: Using a voltmeter marcdsgn Pentax DSLR Discussion 7 07-22-2008 08:12 PM
All times are GMT -7. The time now is 03:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
