Originally posted by TRex1123 I have no flash system as of right now and I am wondering if you were in my shoes would you go with the Cactus RF60 system or the Godox system?
Tough question.
Are you going to use a flash on-camera often? If so, you could save money by using an RF60 as an on-camera flash that doubles as a master for more external flashes.
In any event, make sure you add up all prices for all gadgets you need (the basic Godox price does not even include a receiver). Note also that you won't be able to do the HSS emulation with the Godox since its “Cells II” trigger is currently only available for Canon.
As you wrote, the V6 will be much more convenient (and quicker) when adjusting power remotely and will have many more features compared to the very basic Godox triggers.
On the other hand, the Li-Ion battery of the Godox is very nice, of course. If you want quick recycling and very high battery longevity in a very compact package, the Godox is the right choice. Two things to bear in mind, though:
- The V850 recycles very quickly but it is not a heavy-duty flash. After 20 full power shots in quick succession, it will enter an overheat protection mode, slowing down recycling to 15s between shots. The RF60 also has an overheat protection mode, so it isn't a heavy-duty flash either, but the regular recycling times of the Godox should not make one think it can maintain this performance indefinitely.
- You can connect a power pack to the RF60 which will considerably speed up recycling and significantly increase battery change intervals. The downside is the added bulk. The Canon-compatible power pack takes eight AA batteries and has the respective weight and size. The Godox's Li-Ion battery is a lot more compact in comparison and doesn't require extra mounting.
It really isn't easy to make a decision between these systems. Depending on your priorities, either the Godox or the Cactus is better.
I personally would go for the Cactus system because I don't need the very fast recycling times and wouldn't mind the battery pack if I needed them after all or wanted more stamina. Having played with the V6, I wouldn't want to swap it against an FT-16.
P.S.: There is a way to get the best of both worlds (V6 functionality/handling + Godox battery power): The
Godox V860C can be remote-controlled with a V6. Unfortunately, the V860C is said to be $50 more expensive than the V850, and you'd need two V6 (one on the camera and one for the V860C). As result, this combination becomes quite a bit more costly.
