Originally posted by awaldram Can the port be used as an output as well as an input.?
The RF60's port only works as an input at the moment.
The V6's port supports both input and output at the same time, but only in Tx mode.
In Rx mode, the V6's port only works as an output port and that will have to stay that way so that it can deal with high trigger voltages.
During the beta test phase I asked whether it would be possible to also make the RF60's port an output port and the answer was something like "
We'll have to look into it". I think it wasn't high priority enough to become resolved and I didn't think it was a make or break feature so I didn't follow it up.
You could make a respective
feature request at the Cactus community forum.
Originally posted by awaldram The reason I ask is I'm going to use the V6's in a similar manner firing the Metz hammers off the sync port and additional power controlled flash off the hot shoe this will allow me to use the auto thyristor on the Metz and control 'top off' manually.
Do I understand you correctly that you were planning to fire the Metz from the RF60's sync port?
Even if that worked (it doesn't for now) then I'd be very tempted to get a V6 for the remote power control because a receiving RF60 would definitely not be able to do that via the sync-cable.
