12-05-2014, 04:03 AM   #121
klaus123's Avatar
I have several flashes including 2 RF60 and 2 V6-units.
I do not like the menues of the RF60 as a controller and prefere to have a V6 on the camera - and if I want light there as well i use a 360-Pentax in PTTL / PTTL-trrou mode.
12-05-2014, 06:02 PM   #122
januko's Avatar
Hhmm.. I take on that. Thanks!
12-05-2014, 07:37 PM   #123
Class A's Avatar
QuoteOriginally posted by klaus123 Quote
I think you are comparing "good" with "awesome".
The group control with an RF60 is of course not as convenient and fast as with a V6, but I think it's well done.
I also prefer a V6 on the camera, but if I wanted to use an on-camera flash as well, I'd have no problem using an RF60 to control further flashes (some of which could be RF60 and other that could be connected to a V6).
12-19-2014, 12:47 PM   #124
Hi everybody, let me explain my setup a little:
I have just started using an RF60, off camera, controlled with a V6. It's the first flash that I have ever used.
I have the flash mounted on its side on a light stand using the female stud on the side of the flash. The flash head is sticking straight "up" along the shaft of a Photek Softlighter II umbrella rig.
Now, let me explain the issue I am experiencing:
It seems like there is a blind spot where the wireless signal does not reach the flash. I have not tested it too much, but it seems that there is an area on one side only about 18 inches away from the flash where the V6 cannot connect to the RF60. In this position, for reference, the infrared sensor is pointing towards the camera, the light stand is to my right. If I take pictures from this position the flash does not fire and I can't control the power or zoom. If I back straight up about 6 feet everything appears to work. And, if I take pictures from 18 inches away, but from the other side of the object, and, hence, the other side of the flash, everything appears to work.
My questions are: "Is this a problem inherent to this flash, or, to the way I have it set up, on its side?", and, "I understand that typically you mount these flashes vertically via their hotshoe, could mounting it laterally cause blind spots in certain locations around the flash?"
Thanks.
12-20-2014, 03:58 AM   #125
Class A's Avatar
QuoteOriginally posted by Ansr03 Quote
Now, let me explain the issue I am experiencing:...
I haven't tried to replicate your specific scenario but I would suggest that you try to switch the V6 to the "SHORT" working range mode. You'll find this setting in the sub-menu in the menu.
If a transmitter is too close to a receiver -- and what "close" is depends on the orientation and rotation of both devices -- then the receiver goes into signal overload and cannot decode the signal anymore.
The "SHORT" working range option allows you to get really close, at the expense of reach. Normal distances are still supported, though.
Have a look whether that helps, using the flash on its side or anything else you do is certainly fine in principle.
12-25-2014, 02:30 PM   #126
Thanks for this advice. I did not know that option was available. Unfortunately, it does not seem to solve this issue entirely. I found that with the flash mounted on a lightstand the radio signal can be checked easily from different camera positions by continually switching zoom settings on the V6 while moving the camera about, listening for the zoom motor in the flash. It appears there is a small blind spot projecting straight out from the optical sensor for about 18 inches. From that angle, the connection is only good beyond that distance.
This explains my problems with having the camera, light, and subject close together with the light to the right and the flash mounted on it's side; in this setup the optical sensor is facing the camera and is nearby. I will need to figure out a way to mount it so that the sensor faces the ground or into the umbrella. (Or maybe the light doesn't really need to be that close to the subject when taking closeups--I don't know.)
Thanks.
12-25-2014, 07:08 PM   #127
Class A's Avatar
Interesting, I have never come across that in my testing/use.
If the "SHORT" range option does not help then perhaps you are experiencing a "blind spot" of the RF60 antenna and moving further away just helps the radio signal to better bounce into the antenna from more favourable directions.
The antenna is printed on the PCB of the RF60 so there is no easy way to change its orientation.
Typically, being close to the subject with the light is good as it will provide softer light so I hope you will find a way to change the orientation of the flash somehow. Perhaps mounting it not entirely straight and using head tilt to compensate for the angle will already be sufficient?
12-30-2014, 07:54 AM   #128
Class A's Avatar
Cactus Firmware Updater for Mac released
Apple users with an RF60 can now use the Cactus Firmware Updater for Mac OS X 10.6.8 or above to update the firmware of their RF60 (or V6).
01-01-2015, 03:56 AM   #129
dcBear78's Avatar
Wish these were more widely available. No local sales here in Australia from what I can see.
And anywhere else (ie Andorama) want to rape you on ludicrous postage costs.
01-01-2015, 08:11 AM   #130
Class A's Avatar
QuoteOriginally posted by dcBear78 Quote
There are two dealers in Australia.
01-12-2015, 01:34 AM   #131
Class A's Avatar
HSS / HyperSync without an HSS-capable flash
For those RF60 owners that own at least two V6 and a respective camera release cable, this technique to achieve HSS / HyperSync without P-TTL equipment is perhaps of interest.
01-24-2015, 06:47 AM   #132
klaus123's Avatar
Hello
I was surprised taht every time I pick my V6 transcievers after some weeks the batteries are empty - now I measured the current in off-Position: ~ 1 mA
In future I will store them w/o the batteries!
01-24-2015, 07:06 AM   #133
Class A's Avatar
Interesting observation.
I'll try to find out whether storing with the battery door open, for instance, will cause the V6 to forget the settings.
Hope you've been using rechargeables.
02-03-2015, 08:00 AM   #134
Class A's Avatar
The most recent V6 firmware version (1.1.008) supports both Pentax AF 360 & 540 FGZ II with remote power control.
02-03-2015, 03:33 PM   #135
Hello Class A,
Will V6 can trigger Pentax AF 360 in PTTL ?
Thanks,
steve
cactus, cactus rf60 flash, flash, lighting, photo studio, remote power control, review, rf60, strobist
Cactus V5 radio flash trigger review Class A Flashes, Lighting, and Studio 274 01-22-2019 10:36 PM
Capturing Decisive Moments with Laser Precision – A Review of the Cactus LV5 (beta) Class A Pentax Camera and Field Accessories 46 07-27-2018 08:56 AM
Cactus AF45 flash on K-30 galenus Pentax K-30 & K-50 5 02-26-2015 11:17 PM
Cactus RF60 Flash in Beta Test Phase Class A Flashes, Lighting, and Studio 34 03-27-2014 05:19 PM
All times are GMT -7. The time now is 02:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
