Originally posted by bmw Ah, you've been drinking the Koolaid. :-)
I only use P-TTL when doing indoor event shooting, flash on camera. I still have to chimp a lot and frequently adjust exposure comp.
For all other flash use I go fully manual and incident meter the light where possible. P-TTL is no smarter than the camera's meter and both are fooled by non-average scenes.
I find with 86,0000 reference points P-ttl is often better than my two eyes.
Give the camera half a chance by adjusting correctly and P-ttl will nail the shot
I'd say 99% of the time but truth be known out a 1500+ shots its 1:1.
But then I use the same logic I'd apply to Manual flash and use compensation where I think it will be needed, Using P-ttl to give me latitude that Manual would not allow.
---------- Post added 14-03-14 at 10:37 AM ----------
Originally posted by gosman I notice the manual says in wireless mode to use M or B mode! I wasn't using this when I was using this flash as a slave. Maybe I should just keep it on manual all the time. I did notice that in manual mode and high speed setting I got excellent results outside. Nice balance with existing light.
Something is not right, I can't understand what your doing or what your trying to achieve.
Maybe post an image and explain how you set up the flash/s (channel configuration etc)
Are using wireless with popup as controller and 540 as main light source or 540 on camera etc etc.
