Just out of idle curiosity I decided to dig into the back of the closet and drag out my box of old film camera gear to test my two old and ancient flash units. I used a brand new set of alkaline AA cells and my 15+ years old DVM.
These were the flash units I tested (not my photos but found online):
A Fotomatic 700 TFZ
and
A Nissin 400HA
This is an almost identical DVM to the one I used apart from the brand name (mine is branded as a 'Smart2' which was an old Radio Shack 'store' brand).
I inserted the batteries, set the DVM to the '300' range (upper dial) and 'DC V' option (lower dial) and tested the voltage between the centre 'hot-shoe' contact (+ve lead) and the 'side rail' contact (-ve lead) once the flash units had charged up. In both cases the voltage initially read around 245 V DC and then slowly started to climb at roughly 0.1 volts per second until I stopped taking readings when both units had exceeded 250 V DC.
Needless to say I will
not be using either of these units on my K30 but they could still be used as slave units if hooked to my 30 year old 'magic eye' trigger or some other more modern slave trigger system.
To reinforce what I said in an earlier post you are
not trying to capture the voltage at the instant the xenon tube fires but measuring the voltage the flash unit puts across the 'hot-shoe' contacts when it is in it's charged state. 250 V DC is way too high a voltage for most DSLR cameras to tolerate and the reading I've done recently seems to indicate that most DSLR cameras fall into the 6-20 V DC range in terms of 'safe voltage' depending on the make/model of the camera.
The bottom line is test your gear and do your research
before you put the flash on the camera.
