Originally posted by Class A Thanks!
Yes, for Canon, Nikon, and Pentax but only for a V6 that sits on top of a camera.
Yes, as long as the V6 itself sits on the camera.
In other words, there is no radio transmission of P-TTL signals.
Only power levels and trigger signals are transmitted, so to speak.
Where does my review imply that P-TTL pass-through won't work?
I'd be grateful if you could let me know where and how I seem to be miscommunicating.
Thanks your reply is exactly what I was hoping
What implied to me was bottom of 'optical triggering ' you say
", Canon/Nikon users can also put such a system-dedicated trigger (supporting E-TTL/i-TTL respectively)
on top of a V6 in TTL pass-through mode and thus not only forgo the sync cable but also combine manual flash levels with TTL automatic exposure.
No such system-specific triggers exist for Pentax, though."
Read more at:
Cactus V6 Review - Further Special Features - Pentax Camera Forums
As I wish to combine manual flash levels with p-ttl automatic exposure you seem to be saying it can't be done with Pentax .
---------- Post added 13-05-14 at 09:32 AM ----------
Originally posted by Class A Believe me, it will work as long as recycling times at 1/1 are not too long.
I haven't measured the assumed recycling times in the reference level phase yet, but they become increasingly shorter, the lower the reference power levels are (in order to speed up the whole profiling exercise which only takes ~5min. this way).
For the (manual) reference levels, the V6 only needs to measure the overall light output (the integral over the curve you describe) for a given time (perhaps 1/100s?).
Using a one-stop ND filter in front of the flash or in front of the V6's sensor will thus simulate 1/2 power level.
The actual curve of the flash output should not matter at all at this point.
Later, in the "learning" phase -- when the V6 figures out how to imitate the reference levels by using the quench pin -- the actual output curve matters, but you are not using any ND filters at this stage anymore.
You will not get random levels, but a valid flash profile.
Meeting the recycling time requirements could be a major hurdle, though.
Someone should try this, or I should somehow find the time to at least measure the expected recycling speed at 1/4 power level (the fastest that is absolutely needed).
Ah I understand profiling is done after assessing what 1/2 , 1/4 power looks like .
---------- Post added 13-05-14 at 10:14 AM ----------
Hi Class A
Unless I missed it your review does not point-out the 'pass through' is a selected operating mode of the transmitter and not a hard wired socket-socket this explains at least to me that this unique feature is somthing that I can use.
From the manual
TTL Pass-through
The V6 transceiver comes with a multi-system shoe that supports TTL pass-through.
While the V6 does not transmit TTL signal wirelessly, it is designed to pass TTL signal from camera to flash via the transmitter (TX) and vice versa.
The multi-system shoe supports TTL pass-through of Canon, Fuji film, Nikon,Olympus, Panasonic, and Pentax systems.
Make sure that camera and flash unit belong to the same TTL system.
With TTL pass-through, the TTL flashes behave as they would when directly connected to the camera hot shoe.
The V6 will work as a wireless flash commander while supporting all the automatic features (e.g., automatic flash output via TTL metering, AF assist light, second curtain sync, high speed sync/FP shutter) provided by the TTL flash system.
To enable TTL pass-through in the V6 TX, press and hold for 2 seconds. The LCD will show the TTL pass-through indicator at the left bottom corner where the channel indicator used to be.
In TTL pass-through mode, the V6 TX cannot control the power level of the flash attached.
To disable the TTL pass-through mode, press and hold for 2 seconds. The TTL pass-through indicator will be replaced by the channel indicator on the LCD.
http://www.cactus-image.com/Cactus%20V6%20User%20Manual%20%28EN%29.pdf
