Originally posted by redcat Class A : that's a great great review ! thanks for sharing with us ^^
Glad you found it useful.
Originally posted by redcat Has anyone tested the V6 with a Starblitz TTL flash (or minolta TTL flash) ? I got this Starblitz which support TTL and Manual.
If it has a Minolta hot-shoe then it won't work with the V6. The latter supports a wide range of hot-shoe systems, but Minolta isn't one of them.
The flash would also have to support at least two manual levels.
Originally posted by redcat I only see the ISO slider, I suppose the ISO slider changes flash power @_@
Typically an ISO slider just provides a manual calculator tool for predicting the range (in meters or feet), also depending on the aperture.
You can easily try to see whether it influences the manual flash power by selecting the lowest and the highest settings respectively and check whether it makes a difference to the flash power.
