Originally posted by awaldram HSS to me means High Speed Sync
The operative word being 'Sync'...
I understand where you are coming from but the "sync" aspect of HSS flash lighting is just one aspect, and not even the most important, AFAIC.
You can use the standard trigger signal up to about 1/2000s (on my K-5 II) before you see a black bar appearing at the bottom of the frame. No special sync required until then.
The most important aspect of HSS flash lighting is that the duration of the light is extended to at least 1/180s. Even with a P-TTL HSS supported sync signal, you won't get any usable pictures if the flash duration is shorter than that (which it is for the vast majority of power levels).
Hence, AFAIC, the most important aspect of any HSS technology is the increase in flash duration. As the latter is possible outside P-TTL (and different syncing isn't required up to 1/2000s + there are workarounds for even higher speeds), I don't regard "HSS" as a subfeature of P-TTL.
Originally posted by awaldram Any method that achieves constant artificial lighting by being available for longer than the shutter is open is unmetered environmental lighting which means you'll be using trial and error to get the exposure correct.
Well, you could use a light meter, if you wanted to.
In any event, automatic exposure support and high shutter-speed flash photography are orthogonal topics, AFAIC.
