Originally posted by Class A You can, indeed.
Hope you'll be having as much fun with remote level power control as I'm having. It feels a little bit like cheating, doesn't it?
P.S.: I'm adding the Metz 45-CL4 to the
list of V6 compatible flashes. I'm assuming it is a "for Pentax" model. Please let me know if you encounter any problems with the profile, I'd remove it then again.
You will need to differentiate netween the 45 CL4 and 45 CL4 Digital
Also you need to reference the SCA module in use and and revision number i.e 3702 M2 (Pentax sca 3000 series Rev2 (P-ttl)
sca with three figure i.e 310 (Canon) 371or 2 (pentax) are 300 series for non digital Hammer falshes those with /2 at the end are IR sender modiles i.e 374/2 , the 3000 series is the modern verison and is considerably easier to understand.
SCA 3102 for Canon system cameras (Canon E-TTL / E-TTL II)
SCA 3402 for Nikon system cameras (Nikon i-TTL / D-TTL)
SCA 3202 for Olympus/Panasonic system cameras (Olympus/Panasonic TTL)
SCA 3702 for Pentax system cameras (Pentax P-TTL)
SCA 3302 for Sony system cameras (Sony ADI TTL)
SCA 3502 for Leica cameras R/M (Leica TTL)
SCA 3045 digital connection cable between SCA 3002 adapter and 45 CL 4 digital
