Originally posted by derekkite K3 with F100 2.8 lens and EM-140 ring flash seriously overexposes if I'm closer than 2 feet from the subject. I have the flash ev at -3.0, the lens set at f18, 1/180 shutter in AV mode. P-ttl mode for the flash. The iso shoots up to 3200 or so overexposing.
If I back away 3 feet or more, it settles down. It isn't consistent either. I took some shots of cherry blossoms and was able to adjust things down, and it worked fine. Then shooting some yellow flowers in brighter light, it overexposed.
Any suggestions? I could shoot manual, but am trying to avoid it if I can.
Originally posted by derekkite The iso shoots up to 3200 or so
Are you quite certain you are on straight Av mode? The ISO should remain fixed at whatever you set it to, eg ISO 100 (typical for flash).
