05-05-2014, 10:25 PM   #1
Problem with Cactus V5
Hi,
I have two Cactus v5 devices. On one, when I press the test button, the LED turns orange and green when fully pressed. On other device the LED turns red and then goes dark when fully pressed.
I have swapped the battery packs but the devices behave the same way. Is the one that always shows red defective. maybe?
05-06-2014, 12:24 AM   #2
aurele's Avatar
Red is because the battery is depleted, according to the manual.
05-06-2014, 09:15 AM   #3
QuoteOriginally posted by aurele Quote
I got confused because the same batteries showed red on one device but green on the other. I didn't do anything overnight and this morning both devices showed green.
So all is good for now.
05-10-2014, 10:15 AM   #4
panoguy's Avatar
Most likely the battery drawer on the "red light" unit wasn't fitting properly. V5's have a click-in/out spring-loaded battery holder design that can wear down over time, and the batteries might not both be making contact consistently. I had to reach in and pull the spring out a bit on one of mine last year, but then I'm pretty rough on my gear...
05-10-2014, 01:07 PM   #5
QuoteOriginally posted by panoguy Quote
That may explain why the same unit with showed the red light independently of the batteries used. I don;t know what happened but now both units show green even after changing batteries.
cactus, devices, flash, lighting, photo studio, pressed, strobist, v5
For Sale - Sold: Cactus V5 Flash Trigger Set PRICE DROP EricBrown Sold Items 2 07-10-2013 01:13 PM
[SOLVED] AF 540 FGZ with Cactus V5 problems baro-nite Flashes, Lighting, and Studio 4 06-30-2012 01:51 PM
Pentax 67 with Cactus v5 triggers rajith Pentax Medium Format 6 02-01-2012 05:28 PM
Some help with the Cactus V5, K5 and Pentax 540 jbrowning Flashes, Lighting, and Studio 10 09-02-2011 11:34 AM
cactus V4-V5 not working well with my K20D gybp Flashes, Lighting, and Studio 8 05-16-2011 06:45 PM
All times are GMT -7. The time now is 03:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
