Originally posted by bdery I believe indeed starting with the 52 (and 58 v2) they added the dumb mode, and the lean mode.
Actually, the Metz 58 AF-2 did not implement pre-flash suppression for the Servo mode initially but later firmware updates changed that (it may also be the case that pre-flash suppression was always the case but that just the manual was wrong; I only know for sure that there is an addendum/erratum to the manual, explaining the need for a pre-flash in Servo mode).
My 58 AF-2 (firmware V4.1) requires a pre-flash even in Servo mode.
I'm assuming the same story applies to the 52.
I don't think that it is a good idea to not offer an optical triggering mode that does not require a pre-flash, but then I personally never use optical triggering. Radio triggering is so much easier and more flexible.
