06-26-2014, 05:28 AM   #1
micromacro's Avatar
Promatic TCL 2450 Flash.
I've tried to search all around the web to get any information about TCL flashes, not much luck.
That flash should arrive tomorrow as a part of takumar lenses purchase with Pentax Spotmatic II camera.
It it possible to use that flash on K200D? And what is TCL flash anyway, what's the difference between this one and TTL?
Thanks.
12-26-2014, 08:20 PM   #2
Class A's Avatar
QuoteOriginally posted by micromacro Quote
It is likely that you'll be able to use it on your K200D as long as it has manual controls and its trigger voltage is not over 30V. Unfortunately, no one appears to have measured the trigger voltage of this model yet, so you'd have to do it yourself.
It will be safe to use the flash on a radio trigger that is immune to high trigger voltage, such as the Cactus triggers you appear to have.
12-27-2014, 07:38 AM   #3
micromacro's Avatar
I cleaned contacts, inserted batteries, it works. Fired a few times pushing the test button. Did not measure voltage yet. The manual does not say anything about voltage. There is no way I put it on camera anyway, but maybe I can use it wireless.Seems like cactus will work with this one.
I can take pictures of flash and the manual as well in case someone is interested.
P.S. the voltage was about 120. Then my son switched meter to amp, and booom-s! It took a while to start working again.
flash, lighting, photo studio, promatic tcl, strobist
For Sale - Sold: Pentax K100D and flash **Flash is sold** Camera reduced!!! davidgreen3003 Sold Items 8 07-10-2013 03:52 PM
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Using K 30 onboard flash for fill flash bcorson Pentax K-30 & K-50 12 02-18-2013 04:06 PM
Trigger remote flash without popping up built in flash godavari Flashes, Lighting, and Studio 23 10-15-2012 01:32 PM
Promatic FTD 4000 flash module akope Flashes, Lighting, and Studio 3 12-09-2011 09:05 AM
All times are GMT -7. The time now is 06:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
