What the Cactus V6 will not do:
- Fake the presence of an HSS-capable P-TTL flash.
Unfortunately that means that one needs one P-TTL flash that is HSS-capable connected to the camera in order to get a trigger signal out of a Pentax camera if the shutter speed is beyond the sync speed (1/180s).
What the V6 will do:
- Optically trigger from either the main flash of the HSS-flash (worked fine up to 1/2000s for me) OR
trigger from the pre-flash of the HSS-flash (works at any shutter speed, but requires manually dialling in a delay time -- something like 80ms -- to make sure the V6 does not trigger off-camera flashes too early). - Trigger off-camera flashes with remote power control (no automatic exposure, though, flash power is selected manually on the V6).
The off-camera flashes need to have an HSS mode that can be engaged even if the flash is not mounted to a camera.
The Cactus RF60 is such a flash, and I believe the Godox V850 can do this trick as well. The latter won't support remote power control with the V6, though. The Godox V860C (for Canon) does, but I'm not sure whether it can be put into HSS mode manually.
Alternatively, one can -- as pointed out by bmw -- use Pentax's wireless (i.e., optical) triggering between P-TTL flashes. Drawbacks:
- Optical triggering is not ideal in bright sunlight.
- Line of sight required outdoors (ruling out putting flashes in softboxes; at least I cannot imagine this to work in any reasonable distance to the camera).
- High price for P-TTL HSS flashes.
- Very limited power control over multiple P-TTL flashes.
