I suppose I should explain what I'm trying to do. There are bats that fly through a narrow opening in the trees onto the lake every night, and there are quite a few zipping by for about 10 minutes. The short flash duration is necessary to freeze action; 1/8 on the Metz 50 AF1 gives me about 1/4000 of a second. 1/4 was too slow and the shots were blurred. I discovered that with good batteries it will cycle as fast as the K-3 on low continuous, which eventually ends up being how fast the card gets written. I was sitting 15 feet from the camera, A50 1.4 lens set at f8, which gives me about 8 feet DOF when focused at 15 feet. A 6x6x8 box roughly. Remote trigger, hold the button down and hope. The last session I shot 690 frames. The new Duracell NiMh 2400 mah fed without problem for about 400-450 shots, then started slowing down. I would count to 4 and shoot after that. The flash just worked, didn't complain about heat or anything.
In this shot the bat is not sharp, probably on the far edge of the DOF. I suspect the real DOF is quite a bit narrower. I didn't process post, there is quite a bit to pull from the dark if I want, but the bat isn't sharp so it doesn't look good.
I need more light, so I can stop the lens down even more for a deeper depth of field.
I am considering either the Yongnuo YN560III or the Cactus RF60. My question is whether they are capable of shooting that many shots consecutively without shutting off on high temperature.
