Originally posted by Class A I like the light you created in this portrait;
Thanks!
Quote: I personally would not have underexposed the ambient light quite that much, but the key light is wonderfully warm and soft.
I am all about contrast. By underexposing the background the viewer's focus is put squarely on my subject's face and features. And shadows and darkness especially suits this portrait subject who is into the macabre and all things mysterious and goth.
Quote: I take it, the softbox was very close to the subject?
Somewhere from 1.5 to 2 meters; I don't recall exactly. The little drawing is not to scale.
Quote: Do you have a link to the "cheap eBay 30 inch umbrella softbox" you were using?
Sure.
Photo 80cm 31 5" Octagon Umbrella Flash Softbox Brolly Reflector | eBay
It's probably the best $25 I've ever spent.
Quote: BTW, you could get yourself a pair of Cactus V6 and remote control the power level of your AF540 FGZ. Try that once and then tell me you are going to do it the old way again.
Sure I could. But I've got better ways to spend my money right now.
You know how many times I changed the power of the flash during this shoot? Once: at the beginning when I set up the softbox. After that even though I moved the light several times, each time I placed it by estimating the distance I wanted and then I simply metered the light -- one pop for the meter. No remote power control necessary.
---------- Post added 07-31-14 at 11:08 AM ----------
Originally posted by Class A I notice you are using strip lights.
I never had access to these. Have you used regular softboxes,umbrellas in the respective positions before? Do you like the strip lights better?
When used as a rim light, I'm not quite sure why a strip light should perform better than a regular sized light modifier as the extra light by the regular modifier should just go to waste, right? Or does it cause too much spill?
My guess is that one really wants to have good height out of strip light and that it would be too expensive and not space economical to achieve the same height with a regularly shaped light modifier.
I'd be grateful if you could let me know if there is another merit to using strip lights.
I'll answer this by stepping back a bit. When I am lighting a subject in a studio I am thinking creatively. I'm imagining the subject is an actor in a play, on a stage, and I am the lighting director who is tasked with lighting the actor. I must consider the brightness of the actor relative to his surroundings; shadows that will be cast; the colour of the light; the hardness of the light.
At least these things.
So with a mental picture of how I want my subject to look I start considering how I'm going to achieve that. In a small room with reflective walls I will have issues of reflected light. If I am applying light to specific parts of the subject, eg some extra brightness on her face, I have to consider the possibility of light spill, or unwanted light falling on other areas.
The tools I have to get the control I need include white and black foam core boards and curtains (especially black) to absorb stray light. I can attach barn doors to lights to prevent stray spill. I can attach a Honl speedgrid or a snoot to a bare flash to get a small circle of light.
Then to really accurately place light without spill I have strip lights with grids. These act very much like spotlights: all the light is directed forward in a narrow beam, shaped like a slot; tall (or wide) and narrow. This is perfect for rim lighting of a subject's body (as in "Cabaret") while avoiding spill onto the subject's face. That face spill creates undesirable shadows and hot-spots that have to be laboriously retouched out.
Of course this is all stuff I need to worry about most if I'm doing low-key or chiaroscuro lighting. If I'm doing high-key the considerations are different: I actually want to bounce light around all over the place. In that case I can use umbrellas and large white reflectors. I don't have to worry as much about spill; maybe not at all.
Yes, of course, I've used regular shaped softboxes, umbrellas, v-cards, reflectors ... all the light shaping tools. Each one has its use and place in the toolbox.
BTW, my use of a strip light in the 2-flash shot (Woman seated ...) was as a sort of beauty dish. Highly directed yet soft at the same time. I wasn't using it as a rim light in that case. Nothing wrong with breaking the rules and using lights in creative ways.
