Originally posted by stevebrot Alright - I dig around quiet a bit, so it surprises me I haven't heard of a color temperature meter before.
Originally posted by vonBaloney If you are only interested in setting white balance, then just get an expodisc (or one of the cheap alternative "white balance cap"s) and learn how to use that to set your WB...
Originally posted by jatrax If the light is consistent you can use a gray card or expodisk to set the WB. If light is mixed then you are in a tough situation.
As to actually identifying the temperature from light source used, that used to be possible when most lights were incandescent. These days it is nearly impossible without looking at the bulb and hoping it has a temperature value on it. Tungsten bulbs used to be 2700 - 3000K but they are now available up 5500K. Fluorescent can vary widely and also have color casts that are hard to deal with. LED can be just about anything. Many places are transitioning to new bulb technology so I am finding mixed light sources more common. A mix of old tungsten, CFL and LED is a nightmare.
What bothers me the most are lightsources with green tint in them - I often either can't identify them, or identify them late.
I'm currently working on a bunch of photos where the WB is fine in the beginning - but half an hour later, with slightly lower sun and some light turned off and possible some others turned on (I didn't noticed additional lights being turned on, only that some were turned off), the WB is all over the place and to a degree that surprised me. Greenish here, blue there, orange other places.
The green tint bugs me the most and that's what I'm mostly interested in neutralizing - but when I can't see it, it means I'm not using the proper gel on the flash.
Originally posted by Na Horuk And it only costs $1,216.00! Not much more than the K-3+grip
Regarding temperature.. LED lights are really terrible, because they have highly saturated colour channels, but a very narrow colour spectrum. The other problem you mention is mixed light sources. Both of these are big problems with modern lights, because there are so many types of bulbs, with different characteristics and colour temperatures.
I often just switch to black and white, so I just have to watch composition, focus, and so making sure the photo is not too bright/dark. The other thing you can do in post processing is Split Toning to add a uniform colour cast over the highlights. These are just PP tricks, though. I don't have an answer on what to do beforehand
Many wedding venues here use colored LED's and I always ask for these to be turned off for other that obvious reasons, such as proper partying.
The mixed WB's is a complete mess and I'm seeing this many many places. On the fancier places, however, the WB is generally much more even.
---------- Post added 07-10-14 at 19:44 ----------
Originally posted by tuco You have to pay to play
I'll take white LED lights over those terrible orange street lights any day.
I really really dislike those as well. Nice light and wonderful WB going on in the pic.
