Originally posted by Ptr_Mrtn So when using HSS, can you shoot on manual exposure?
Yes, no problem.
Originally posted by Ptr_Mrtn I heard you have to shoot PTTL when using HSS.
The on-camera flash has to be in P-TTL mode, P-TTL HSS to be exact.
Other than that, I'm not aware of any limitations.
Originally posted by Ptr_Mrtn p.s. Some flashes are slower and some are faster at full power. My Yongnuo flashes fire at 320th of a second at full power and the old Vivitar 285s fire at around 800th at full power.
Be careful to distinguish between T.1 and T.5 times.
Many manufacturers provide T.5 times (the time for the flash output to fall below 50%). This time is shorter than the more useful T.1 times (the time for the flash output to fall below 10%).
A less powerful flash will have a shorter full power output pulse, but flashes with approximately the same output power will have approximately the same output duration. It just takes some time for the capacitor to fully discharge. Note that at 1/180s, you will cut off a tiny bit of the full power of most flashes, as they are unable to deliver all of it in such a short period.
